[postgis-devel] External Doc Deps
Paragon Corporation lr at pcorp.us
Tue Nov 20 22:54:48 PST 2012
On further inspection this is a long standing issue.  The xml file really is
broken.
It happens in the step when the postgis.xml is copied and svn number
stamped.  Sometimes something goes wrong and the original gets corrupted.
HINT: We should probably have this as part of our building process rather
than a hack in a script (I copied it from Kevin's old script so no I did not
come up with this solution)
I'm not sure why Hudson never had issue or if it's a contention problem.
I created a hack job a while back when I first noticed it. It's a job called
"PostGIS Delete Broken XML".
It just delets the postgis.xml, postgis.xml.orig so that on next job run,
debbie is forced to repull a good copy of postgis.xml.
Just run it and then rerun the build job if this happens again and things
should go back to normal.
You are on your own for the next couple of days since I'll be out of the
country.
Thanks,
Regina
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Tuesday, November 20, 2012 11:54 PM
To: 'PostGIS Development Discussion'
Subject: Re: [postgis-devel] External Doc Deps
Hmm -- she has docbook installed so she shouldn't need to pull it.  Winnie
has docbook installed as well.  It was just the mathml part I couldn't
figure out how to install.
I'll check on her.  Might just need to restart the jenkins service.  I think
I've seen some other peculiar stuff suggesting memory leak in jenkins.
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Tuesday, November 20, 2012 7:51 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] External Doc Deps
Builds are still transiently failing due to external DTDs, I think.
Without MML things are better, but we still have this one:
<!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML V4.5//EN"
                    "http://www.oasis-open.org/docbook/xml/4.5/docbookx.dtd"
I think debbie is currently failing because she can't get to it (could be
wrong).
P.
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
