[postgis-devel] External Doc Deps
George Silva georger.silva at gmail.com
Wed Nov 21 02:46:45 PST 2012
Do this have to do with our internationalization efforts? Perhaps gettext
is building a broken docbook file?
Since we are talking about it, did we decided which pathways we are going
to take to translate the docs? I remember that we had a few software
options...
George
On Wed, Nov 21, 2012 at 4:54 AM, Paragon Corporation <lr at pcorp.us> wrote:
> On further inspection this is a long standing issue.  The xml file really
> is
> broken.
> It happens in the step when the postgis.xml is copied and svn number
> stamped.  Sometimes something goes wrong and the original gets corrupted.
> HINT: We should probably have this as part of our building process rather
> than a hack in a script (I copied it from Kevin's old script so no I did
> not
> come up with this solution)
> I'm not sure why Hudson never had issue or if it's a contention problem.
> I created a hack job a while back when I first noticed it. It's a job
> called
> "PostGIS Delete Broken XML".
> It just delets the postgis.xml, postgis.xml.orig so that on next job run,
> debbie is forced to repull a good copy of postgis.xml.
> Just run it and then rerun the build job if this happens again and things
> should go back to normal.
> You are on your own for the next couple of days since I'll be out of the
> country.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paragon
> Corporation
> Sent: Tuesday, November 20, 2012 11:54 PM
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] External Doc Deps
> Hmm -- she has docbook installed so she shouldn't need to pull it.  Winnie
> has docbook installed as well.  It was just the mathml part I couldn't
> figure out how to install.
> I'll check on her.  Might just need to restart the jenkins service.  I
> think
> I've seen some other peculiar stuff suggesting memory leak in jenkins.
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Tuesday, November 20, 2012 7:51 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] External Doc Deps
> Builds are still transiently failing due to external DTDs, I think.
> Without MML things are better, but we still have this one:
> <!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML V4.5//EN"
> http://www.oasis-open.org/docbook/xml/4.5/docbookx.dtd"
> I think debbie is currently failing because she can't get to it (could be
> wrong).
> P.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
George R. C. Silva
Desenvolvimento em GIS
http://geoprocessamento.net
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20121121/ce908749/attachment.html>
