[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Wed Nov 28 05:32:11 PST 2012
  Reporter:  pierrevandelaar        |       Owner:  robe
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  fixed                  |    Keywords:
Comment(by robe):
 tastle,
 I haven't tested 9.1.6 since I'm running 9.2x64 in production.  The issue
 is usually with the libxml2-2.dll.  They may have upgraded their libxml
 version or changed the name again.  Ah the bain of my existence.
 If you have a libxml2.dll, try copying over to libxml2-2.dll and see if
 that solves your problem.
 How did you install? did you use stackbuilder or just the zip file? This
 issue happens also if you accidentally pulled the 32-bit dlls instead of
 the 64-bit ones.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:10>
