[postgis-devel] [PostGIS] #1653: [raster] ST_Transform & ST_Resample are confusing
PostGIS trac at osgeo.org
Wed Nov 28 17:21:20 PST 2012
 Reporter:  pracine      |       Owner:  pracine
     Type:  enhancement  |      Status:  new
 Priority:  high         |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Comment(by pracine):
 Now that ST_Transform has an alignment parameter, you could easily remove
 the confusion in ST_Resample() by renaming  _st_resample()to
 _st_gdalwarp() (what it truly is) and remove the SRID parameter from
 ST_Resample().
 This way we have a set of usual functions each using the confusing GDAL
 Warp but avoiding the confusion. I don't know any other raster package
 mixing resampling and reprojecting in a unique function. I know
 reprojecting involves resampling but resampling certainly does not involve
 reprojecting.
 It's not because GDAL is confusing that we have to do the same...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1653#comment:10>
