[postgis-devel] [PostGIS] #2121: stop validating dtd for comments generation
PostGIS trac at osgeo.org
Fri Nov 30 01:20:08 PST 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.3
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 I am so tired of gettting build bot failures everytime dtd validation
 checks fail. This often happens because of network failures downloading
 dtd.
 I propose we change the comments generation sections to the form
 postgis_comments.sql: ./xsl/postgis_comments.sql.xsl $(XML_INPUTS)
         $(XSLTPROC) --novalid ./xsl/postgis_comments.sql.xsl postgis-
 out.xml > $@
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2121>
