[postgis-devel] [PostGIS] #2122: [raster] Real extent feature lost after metadata as views
Sandro Santilli strk at keybit.net
Fri Nov 30 08:28:07 PST 2012
On Fri, Nov 30, 2012 at 08:24:07AM -0800, Bborie Park wrote:
> On Fri, Nov 30, 2012 at 8:16 AM, Sandro Santilli <strk at keybit.net> wrote:
> > On Fri, Nov 30, 2012 at 08:07:57AM -0800, Bborie Park wrote:
> >> > Couldn't (or doesn't) a constraint contain the original extent ?
> >> > The same information that you would have put into the raster_column field.
> >> It could be done as a constraint... a constraint that does not enforce
> >> anything.  The problem with constraints that don't enforce anything is
> >> that they're static and may go out of date...
> > It could also constraint: all raster tiles  must be covered bu that extent.
> >> There are a whole set of constraints present...
> >> srid
> >> extent
> > ^^^ so there's one already ?
> Yes. This is a constraint enforcing that all tiles are within the
> maximum extent for the table. A "true" data extent constraint would be
> something else though that would be hard to enforce due to probable
> performance issues.
You could just make the test looser... no tile can be fully outside
the real extent, and in no way above or on the left. Can overlap on
the right and on the bottom, but not be fully outside.
Should be fast.
How does the loader request regular blocking ?
Is there an AddRasterColumn function to call, taking care about writing
those constraints ?
--strk;
