[postgis-devel] [PostGIS] #2122: [raster] Real extent feature lost after metadata as views
Mateusz Loskot mateusz at loskot.net
Fri Nov 30 08:36:18 PST 2012
On 30 November 2012 16:16, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Nov 30, 2012 at 08:07:57AM -0800, Bborie Park wrote:
>> > Couldn't (or doesn't) a constraint contain the original extent ?
>> > The same information that you would have put into the raster_column field.
>> It could be done as a constraint... a constraint that does not enforce
>> anything.  The problem with constraints that don't enforce anything is
>> that they're static and may go out of date...
> It could also constraint: all raster tiles  must be covered bu that extent.
>> There are a whole set of constraints present...
>> srid
>> extent
> ^^^ so there's one already ?
Yes, it is not sufficient in the non-evenly tiled raster.
See the 256x256 vs 300x300 example I posted in the ticket.
Best regards
Mateusz Loskot, http://mateusz.loskot.net
