[postgis-devel] [PostGIS] #2122: [raster] Real extent feature lost after metadata as views
Sandro Santilli strk at keybit.net
Fri Nov 30 09:18:21 PST 2012
On Fri, Nov 30, 2012 at 05:16:40PM +0000, Mateusz Loskot wrote:
> On 30 November 2012 17:11, Sandro Santilli <strk at keybit.net> wrote:
> > On Fri, Nov 30, 2012 at 09:03:54AM -0800, Bborie Park wrote:
> >> The original extent was computed by unioning the tiles' convex hulls
> >> when adding that constraint. raster2pgsql just added the necessary
> >> calls to AddRasterConstraints().
> > This conflicts with what Mateusz said, right ?
> > Or did I miss anything ?
> There are two loaders behind single name :)
> raster2pgsql (the current version, implemented in C)
> raster2pgsql.py (formerly known as gdal2wktraster.py, deprecated)
> That is why I used past tense in my explanation, to indicate "how it
> used to be".
> I wrote the gdal2wktraster.py (raster2pgsql.py) only and it was in
> pre-view/constraints times.
Ouch. So, which package ships which version ?
Are the two loaders compatible under every other aspect ?
--strk;
