[postgis-devel] [PostGIS] #1984: geography_btree.c: array subscript is above array bounds [-Warray-bounds]
PostGIS trac at osgeo.org
Mon Oct 1 02:01:04 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Ok the issue here is GIDX->c being defined as a 1-element array, while we
 know it's of variable size instead.
 One way to fix this would be changing its definition from:
  typedef struct
         int32 varsize;
         float c[1];
  } GIDX;
 To:
  typedef struct
         int32 varsize;
         float c[];
  } GIDX;
 But doing so would change sizeof(GIDX) to be one float less than possibly
 expected by client code. This may actually simplify some code, but doesn't
 look like we have much testing for that (nothing in the testsuite fails
 with the above changes).
 Another way could be doing the cast from within the GIDX_* macros which
 are using subscripts. Probably safer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1984#comment:1>
