[postgis-devel] [PostGIS] #2034: ST_3DClosestPoint with mixed dimensionality in input values
PostGIS trac at osgeo.org
Fri Oct 5 12:22:05 PDT 2012
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.2
Component:  postgis      |     Version:  trunk
 Keywords:               |
Description changed by nicklas:
Old description:
> In the example in #2034, there is input of 2d and 3d. ST_3DClosestPoint
> then by design assumes that the 2d value have a zero Z-value. But I guess
> it is more like undefined.
> So I think that the most correct solution maybe is to handle the POINT(6
> 0) in ST_3DClosestPoint function as a infinite vertical line crossing
> POINT(6 0). Then the answer would be what strk expects in #2032.
> I want feedback before I try to do anything about it.
New description:
 In the example in #2032, there is input of 2d and 3d. ST_3DClosestPoint
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2034#comment:1>
