[postgis-devel] [PostGIS] #2033: 2.5D topology: Column has Z dimension but geometry does not
PostGIS trac at osgeo.org
Sat Oct 6 06:32:04 PDT 2012
  Reporter:  strk      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.2
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:  history
Changes (by strk):
  * keywords:  => history
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Because it won't give me 2d results when fed 2d input ...
 Anyway this case is closed with r10378 in 2.0 branch and r10381 in trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2033#comment:2>
