[postgis-devel] pt_br docs
Sandro Santilli strk at keybit.net
Thu Oct 11 05:21:07 PDT 2012
Thanks George. I'm trying it but having a problem, unfortunately:
 po2xml ../../introduction.xml introduction.xml.po > introduction.xml
 terminate called after throwing an instance of 'antlr::TokenStreamRecognitionException'
 Aborted (core dumped)
You can test yourself too:
 $ cd doc/po/pt_BR
 $ make
I will need a ticket for this as can't work on it immediately.
Thanks!
--strk;
On Thu, Oct 11, 2012 at 08:49:02AM -0300, George Silva wrote:
> I've made a pull request via github.
> If you want to merge directly, take a look at my github repository:
> https://github.com/george-silva/postgis
> I'm translating directly in the svn-trunk branch.
> On Wed, Oct 10, 2012 at 7:32 PM, Sandro Santilli <strk at keybit.net> wrote:
> > On Wed, Oct 10, 2012 at 03:07:55PM -0300, George Silva wrote:
> > > Hello folks,
> > > I've managed to translate the entire introduction.xml file.
> > > strk, I think we could run a little build test for these documents?
> > I think it's all setup to run the tests on commit (and the result
> > should actually be directly published)
> > > Let's see how this will turn out?
> > > Right now it's all in my fork. I'll make a pull request for the official
> > > PostGIS repo?
> > Yes please, or just push your branch somewhere and report here
> > the public repo url and the branch name ( I won't merge pull
> > requests with the github interface anyway ).
> > --strk;
> >  http://www.cartodb.com - Map, analyze and build applications with your
> > data
> >                                        ~~ http://strk.keybit.net
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> George R. C. Silva
> Desenvolvimento em GIS
> http://geoprocessamento.net
> http://blog.geoprocessamento.net
 http://www.cartodb.com - Map, analyze and build applications with your data
