[postgis-devel] pt_br docs
George Silva georger.silva at gmail.com
Thu Oct 11 05:23:21 PDT 2012
This is weird. Probably some error on the translation?
Let me check everything again and I'll let you know.
On Thu, Oct 11, 2012 at 9:21 AM, Sandro Santilli <strk at keybit.net> wrote:
> Thanks George. I'm trying it but having a problem, unfortunately:
>  po2xml ../../introduction.xml introduction.xml.po > introduction.xml
>  terminate called after throwing an instance of
> 'antlr::TokenStreamRecognitionException'
>  Aborted (core dumped)
> You can test yourself too:
>  $ cd doc/po/pt_BR
>  $ make
> I will need a ticket for this as can't work on it immediately.
> Thanks!
> --strk;
> On Thu, Oct 11, 2012 at 08:49:02AM -0300, George Silva wrote:
> > I've made a pull request via github.
> > If you want to merge directly, take a look at my github repository:
> > https://github.com/george-silva/postgis
> > I'm translating directly in the svn-trunk branch.
> > On Wed, Oct 10, 2012 at 7:32 PM, Sandro Santilli <strk at keybit.net>
> wrote:
> > > On Wed, Oct 10, 2012 at 03:07:55PM -0300, George Silva wrote:
> > > > Hello folks,
> > > > I've managed to translate the entire introduction.xml file.
> > > > strk, I think we could run a little build test for these documents?
> > > I think it's all setup to run the tests on commit (and the result
> > > should actually be directly published)
> > > > Let's see how this will turn out?
> > > > Right now it's all in my fork. I'll make a pull request for the
> official
> > > > PostGIS repo?
> > > Yes please, or just push your branch somewhere and report here
> > > the public repo url and the branch name ( I won't merge pull
> > > requests with the github interface anyway ).
> > > --strk;
> > >  http://www.cartodb.com - Map, analyze and build applications with
> your
> > > data
> > >                                        ~~ http://strk.keybit.net
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> > George R. C. Silva
> > Desenvolvimento em GIS
> > http://geoprocessamento.net
> > http://blog.geoprocessamento.net
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
George R. C. Silva
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20121011/1d1be86a/attachment.html>
