[postgis-devel] Can we stop using .c prefix for SQL files ?
Sandro Santilli strk at keybit.net
Fri Oct 12 00:59:55 PDT 2012
Pretty please ?
I think I've changed the Makefile to use an SQLPP command which
should resolve to proper CPP now (no more GCC -E) which in turn
should not care about the file extension.
Maybe the easier would be for me to just commit the change and
see what happens, unless our bots have a way to be configured
for building an experimental git branch, do they ?
Or Robe: are you willing to add this feature ?
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
