[postgis-devel] [PostGIS] #2045: pgsql2shp should not require temp table creation privs when dumping a query
PostGIS trac at osgeo.org
Fri Oct 12 09:59:10 PDT 2012
 Reporter:  strk           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
 If you can't create a temporary table, then you can't get a shapefile out
 of a query using pgsql2shp. You can by using ogr2ogr.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2045>
