[postgis-devel] [PostGIS] #2039: ST_Area(geography) returning wrong answer
PostGIS trac at osgeo.org
Fri Oct 12 12:21:37 PDT 2012
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by pclark):
 This works for me using r10420; hadn't tried r10407. The results aren't
 identical, but they're close enough for what I care about - the
 discrepancy between the two polygons is on the order of 500 square cm, as
 opposed to twice the area of California like they were in postgis 2.0.1.
  WITH shapes as (
   select 1 as rownum, ST_GeogFromText('POLYGON((-144 -63,-144 -54,-126
 -54,-126 -63,-144 -63))') as shape
   union
   select 2 as rownum, ST_GeogFromText('POLYGON((-90 -63,-90 -54,-72
 -54,-72 -63,-90 -63))') as shape
   select rownum, ST_Area(shape) as spheroid, ST_Area(shape, false) as
 sphere,
         ST_Area(shape) - ST_Area(shape, false) as delta
   from shapes;
 returns
   rownum |     spheroid     |      sphere      |      delta
        1 | 1040833443426.79 |  1035406049943.1 | 5427393483.68726
        2 | 1040833443426.79 | 1035406049943.05 | 5427393483.73877
  (2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2039#comment:2>
