[postgis-devel] [PostGIS] #2047: debbie not registering error on regress compile failure
PostGIS trac at osgeo.org
Sat Oct 13 05:45:23 PDT 2012
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
 It seems if regress fails during compile, Debbie doesn't register as
 failure and remarks success.  Winnie seems to fail correctly on make
 failures during regress.
 I saw it when I setup a Postgres 9.0 regress.
 I think it might be this line
 if [ "$?" != "0" ]; then
   exit $?
 fi
 Because when I take it out, it correctly fails.  I'm going to remove it
 from the regular regress script to see if it fixes the issue,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2047>
