[postgis-devel] [PostGIS] #2048: Regress failure for 9.0
PostGIS trac at osgeo.org
Sun Oct 14 05:53:07 PDT 2012
 Reporter:  robe     |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 Output from winnie
 Running tests
  check_gdal .. ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  rt_metadata .. ok
  rt_raster2worldcoord .. ok
  rt_world2rastercoord .. ok
  rt_above .. ok
  rt_below .. ok
  rt_contained .. ok
  rt_contain .. ok
  rt_left .. ok
  rt_overabove .. ok
  rt_overbelow .. ok
  rt_overlap .. ok
  rt_overleft .. ok
  rt_overright .. ok
  rt_right .. ok
  rt_same .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_setvalues_array .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  rt_neighborhood .. ok
  rt_nearestvalue .. ok
  rt_pixelofvalue .. ok
  rt_pixelaspolygons .. ok
  rt_pixelaspoints .. ok
  rt_pixelascentroids .. ok
  rt_polygon .. ok
  rt_utility .. ok
  rt_asgdalraster .. ok
  rt_astiff .. ok
  rt_asjpeg .. ok
  rt_aspng .. ok
  rt_reclass .. ok
  rt_resample .. ok
  rt_asraster .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  rt_intersection .. ok
  rt_clip .. ok
  rt_mapalgebra .. failed (diff expected obtained:
 /c/jenkins/postgis/tmp/2.1.0SVN_pg9.0w64/test_67_diff)
  rt_union .. ok
  rt_invdistweight4ma .. ok
  rt_4ma .. ok
  rt_intersects .. ok
  rt_overlaps .. ok
  rt_touches .. ok
  rt_contains .. ok
  rt_containsproperly .. ok
  rt_covers .. ok
  rt_coveredby .. ok
  rt_within .. ok
  rt_disjoint .. ok
  rt_dwithin .. ok
  rt_dfullywithin .. ok
  rt_samealignment .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic ..... ok
  loader/BasicCopy ..... ok
  loader/Tiled10x10 .... ok
  loader/Tiled10x10Copy .... ok
  uninstall .. ok (3740
 Run tests: 89
 Failed: 1
 Same failure from Debbie:
 See attached output from winnie
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2048>
