[postgis-devel] Question about SUSE Geo repository & Postgres/postgis
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Oct 15 10:02:33 PDT 2012
That is because v2.0 was never successfully built:
https://build.opensuse.org/package/show?package=postgis2&project=Application%3AGeo
On 10/15/2012 07:46 PM, pcreso at pcreso.com wrote:
> Hi Angelos,
> What exactly do you mean by "fixing"?
> The files list at
> http://download.opensuse.org/repositories/Application:/Geo/SLE_11_SP2/
> which I figure is the  "official Application:Geo" repository you are referring to does not have Postgis v2.0.1, only v1.5.4
> At least that I have found.
> Cheers,
>     Brent Wood
> --- On Tue, 10/16/12, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
> From: Angelos Tzotsos <gcpp.kalxas at gmail.com>
> Subject: Re: [postgis-devel] Question about SUSE Geo repository & Postgres/postgis
> To: pcreso at pcreso.com
> Cc: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>, opensuse at dstoecker.de
> Date: Tuesday, October 16, 2012, 5:38 AM
> Hi,
> In that case, fixing the build for official Application:Geo would be a better solution, since postgis 2.0.1 is already there.
> Best,
> Angelos
> On 10/15/2012 07:28 PM, pcreso at pcreso.com wrote:
>> Hi Angelos,
>> In theory, yes, I believe Postgres 9.1 is available for SLES11 SP2, so if Postgis 2.0.1 was built against the standard Postgres install that should be fine.
>> Appreciated.
>> Brent Wood
>> To: postgis-devel at postgis.refractions.net
>> Cc: opensuse at dstoecker.de
>> Date: Monday, October 15, 2012, 7:55 PM
>>                   On 10/15/2012 01:34 AM,
>>                    Hi,
>> Is it possible to have the maintainers of this repository build a similar set of Postgres 9.2 & matching Postgis 2.0.1 packages for SLES11 SP2?
>> http://download.opensuse.org/repositories/Application:/Geo:/Postgres9PostGIS1/SLE_11_SP1/
>> Thanks,
>>      Brent Wood
>>          _______________________________________________
>> postgis-devel mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>             Hi Brent,
>>        I think adding postgis2 to this repository would be enough for what
>>        you need, right?
>>        Regards,
>>        Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
>> -----Inline Attachment Follows-----
> -- Angelos Tzotsos
Angelos Tzotsos
