[postgis-devel] Fwd: ST_DumpPoints in C
Paul Ramsey pramsey at opengeo.org
Mon Oct 15 11:38:00 PDT 2012
Gift horse, see mouth. I'm happy to have a contribution here, on a
ticket which has gone un-worked for over two years.
P.
On Mon, Oct 15, 2012 at 11:35 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Oct 15, 2012 at 06:20:18PM +0000, Nathan Wagner wrote:
>> On Mon, Oct 15, 2012 at 11:00:29AM -0700, Paul Ramsey wrote:
>> > It's not mine, it's Nathan's...
>> > the URL to clone is
>> > https://pd.if.org/git/dumppoints
>> > and it's not a patch on PostGIS, it's an extension that depends on PostGIS
>> I thought it would make testing and use easier if it could be
>> vetted as an extension before it was merged into PostGIS proper.
>> I've only tested against Postgres 9.2 and postgis 2.0.  I don't
>> see any particular reason why it wouldn't work with other versions,
>> but I may have used some lwgeom functions or struct members that
>> are particular to 2.0.
> If you maintained a fork of the git repo currently on github it would
> have been easier to test, and less integration work for merging in...
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your data
>                                        ~~ http://strk.keybit.net
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
