[postgis-devel] Fwd: ST_DumpPoints in C
Paul Ramsey pramsey at opengeo.org
Mon Oct 15 11:45:05 PDT 2012
git config http.sslVerify false
On Mon, Oct 15, 2012 at 11:41 AM, Sandro Santilli <strk at keybit.net> wrote:
> Yes, of course I'm happy for the gift. Thank you Nathan !
> About the clone url:
>  [strk at gnash:~] git clone https://pd.if.org/git/dumppoints
>  Cloning into 'dumppoints'...
>  error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none while accessing https://pd.if.org/git/dumppoints/info/refs
>  fatal: HTTP request failed
>  [strk at gnash:~] git clone http://pd.if.org/git/dumppoints
>  error: Failed connect to pd.if.org:80; Connection refused while accessing http://pd.if.org/git/dumppoints/info/refs
> --strk;
> On Mon, Oct 15, 2012 at 11:38:00AM -0700, Paul Ramsey wrote:
>> Gift horse, see mouth. I'm happy to have a contribution here, on a
>> ticket which has gone un-worked for over two years.
>> P.
>> On Mon, Oct 15, 2012 at 11:35 AM, Sandro Santilli <strk at keybit.net> wrote:
>> > On Mon, Oct 15, 2012 at 06:20:18PM +0000, Nathan Wagner wrote:
>> >> On Mon, Oct 15, 2012 at 11:00:29AM -0700, Paul Ramsey wrote:
>> >> > It's not mine, it's Nathan's...
>> >> > the URL to clone is
>> >> > and it's not a patch on PostGIS, it's an extension that depends on PostGIS
>> >> I thought it would make testing and use easier if it could be
>> >> vetted as an extension before it was merged into PostGIS proper.
>> >> I've only tested against Postgres 9.2 and postgis 2.0.  I don't
>> >> see any particular reason why it wouldn't work with other versions,
>> >> but I may have used some lwgeom functions or struct members that
>> >> are particular to 2.0.
>> > If you maintained a fork of the git repo currently on github it would
>> > have been easier to test, and less integration work for merging in...
>> > --strk;
>> >  http://www.cartodb.com - Map, analyze and build applications with your data
>> >                                        ~~ http://strk.keybit.net
>> > _______________________________________________
>> > postgis-devel mailing list
>> > postgis-devel at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
