[postgis-devel] [PostGIS] #1980: Allow overriding mathml location (was: Winnie hiccuping on mathml doc html)
PostGIS trac at osgeo.org
Tue Oct 16 17:13:57 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.2
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Changes (by robe):
  * owner:  robe => strk
  * component:  buildbots => build/upgrade/install
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.2
Comment:
 Okay I researched this some more and as far as I can tell the local paths
 where mathml is looked for are hard-coded in configure.ac.
 Debbie happened to have mathml installed in one of the locations searched
 so I for now I copied to winnie's to path
 msys/usr/share/xml/schema/w3c/mathml/dtd folder so that it doesn't have to
 be downloaded each time.
 It would be really nice to be able to just override this MATHML2_DTD
 variable as it just causes all sorts of stupid false alarms for check when
 something goes wrong with downloading mathml file not to mention the
 wasted bandwidth.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1980#comment:3>
