[postgis-devel] [PostGIS] #2060: GetTopoGeomElementArray: ERROR: value for domain topoelementarray violates check constraint "dimensions"
PostGIS trac at osgeo.org
Sun Oct 21 10:11:13 PDT 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 OOps, there is:
 CREATE DOMAIN topology.TopoElement AS integer[]
   CONSTRAINT DIMENSIONS CHECK (
     array_upper(VALUE, 2) IS NULL
     AND array_upper(VALUE, 1) = 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2060#comment:2>
