[postgis-devel] [PostGIS] #2017: Assign Winnie or Debbie to build doxygen docs
PostGIS trac at osgeo.org
Tue Oct 23 17:57:56 PDT 2012
  Reporter:  robe       |       Owner:  robe
      Type:  task       |      Status:  closed
  Priority:  medium     |   Milestone:  Management 2.0
 Component:  buildbots  |     Version:  trunk
Resolution:  fixed      |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I'm going to consider this done enough.  will put translate as separate.
 Right now debbie is build postgis 2.1 en docs and the br and it versions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2017#comment:5>
