[postgis-devel] [PostGIS] #2064: Setup Debbie to build and test 1.5 branch
PostGIS trac at osgeo.org
Sun Oct 28 04:04:31 PDT 2012
 Reporter:  robe       |       Owner:  robe
     Type:  task       |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 1.5.6
Component:  buildbots  |     Version:  1.5.X
 Keywords:             |
Comment(by robe):
 I setup a job to build PostGIS 1.5 branch.  The odd thing is that it's
 registering
 revision as r10529 which oddly enough agrees with the number I am seeing
 in pramsey's last commit to that branch.  but the revision of the branch
 is r10578.
 I would expect these two revision numbers to agree.
 Still need to put in a job to build the docs so will keep this ticket open
 for now.
 This build also only checks every 4 hours to minimize risk of colliding
 with others.  It seems we still have an issue with that with 2.0 and 2.1
 that I haven't figured out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2064#comment:1>
