[postgis-devel] [PostGIS] #2068: [raster] Make out_db column of raster_columns view behave correctly
PostGIS trac at osgeo.org
Mon Oct 29 10:53:35 PDT 2012
 Reporter:  dustymugs  |       Owner:  dustymugs
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.2
Component:  raster     |     Version:  2.0.x
 Keywords:             |
Comment(by dustymugs):
 In looking to fix this, I found that the code is already present and
 working correctly.  Double-checking my production data warehouse,
 everything looks to be working... I just forgot to add the outdb
 constraint to a large set of columns.  Once the constraint was added,
 everything worked as expected.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2068#comment:3>
