[postgis-devel] [postgis-users] PostGIS 1.5.5 and PostgreSQL 9.2
Paul Ramsey pramsey at opengeo.org
Tue Oct 30 09:45:24 PDT 2012
No, we don't have a calendrical release schedule, but the backlog of
fixes complete for 1.5.6 is actually a pretty impressive nest of
crashers and improvements, so I'm sure we could be poked into it...
 - Bug Fixes
   - #547, ST_Contains memory problems, the remake
   - #1957, ST_Distance to a one-point LineString returns NULL
   - #1936, ST_GeomFromGML on CurvePolygon causes server crash
   - #1953, Segfault on GEOS calls with empty polygon
   - #1976, Geography point-in-ring code overhauled for more reliability
   - #2071, Add PgSQL 9.2 support
P.
On Tue, Oct 30, 2012 at 5:15 AM, Ilie, Radu <rilie at wsi.com> wrote:
> Thank you very much for the prompt response. Do you have at least a rough estimate for when the next patch release is going to be?
> Radu Ilie
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Monday, October 29, 2012 2:04 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS 1.5.5 and PostgreSQL 9.2
> No, it was not supported, it is in svn now, and will be at next patch release
> http://trac.osgeo.org/postgis/ticket/2071
> P.
> On Mon, Oct 29, 2012 at 7:04 AM, Ilie, Radu <rilie at wsi.com> wrote:
>> Yes, I did. The error is this:
>> gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
>> -Wdeclaration-after-statement -Wendif-labels
>> -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing
>> -fwrapv -g -fpic
>> -I/perforce/DATARC_auto/DATARC/products/AggServer/dev/main/BUILD_AREA/
>> INSTALL/usr/local/pgsql/include
>> -I/usr/include/libxml2 -I../liblwgeom -I. -I.
>> INSTALL/usr/local/pgsql/include/server
>> -I/perforce/DATARC_auto/DATARC/products/AggServer/dev/main/BUILD_AREA/INSTALL/usr/local/pgsql/include/internal
>> -D_GNU_SOURCE -I/usr/include/libxml2   -c -o lwgeom_estimate.o
>> lwgeom_estimate.c
>> lwgeom_estimate.c: In function 'LWGEOM_gist_joinsel':
>> lwgeom_estimate.c:318: error: 'Form_pg_class' undeclared (first use in
>> this
>> function)
>> lwgeom_estimate.c:318: error: (Each undeclared identifier is reported
>> only once
>> lwgeom_estimate.c:318: error: for each function it appears in.)
>> lwgeom_estimate.c:318: error: expected ';' before 'reltup'
>> lwgeom_estimate.c:319: error: 'reltup' undeclared (first use in this
>> function)
>> lwgeom_estimate.c:330: error: expected ';' before 'reltup'
>> make[1]: *** [lwgeom_estimate.o] Error 1
>> Radu
>> Jeff Lake
>> Sent: Monday, October 29, 2012 9:59 AM
>> Did you specify the path to pg_config ??
>> eg:
>> ./configure --with-pgconfig=/usr/pgsql-9.2/bin/pg_config
>> Jeff Lake
>> MichiganWxSystem
>> AllisonHouse
>> GRLevelXStuff
>> On 10/29/2012 9:49, Ilie, Radu wrote:
>> Hi,
>> I am getting build errors when trying to build PostGIS 1.5.5 against
>> PostgreSQL 9.2.1. Is this a known problem? If yes, do you know when it
>> will be fixed?
>> Thank you,
>> Radu Ilie
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
