[postgis-devel] [PostGIS] #1971: rtpostgis_upgrade_20_minor.sql:530: ERROR: syntax error at or near "DO"
trac at osgeo.org
Sat Sep 1 05:30:49 PDT 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Running `make check` against PostgreSQL 8.4 with PostGIS trunk triggers
this error:
psql:/home/src/postgis/postgis/regress/00-regress-
install/share/contrib/postgis/rtpostgis_upgrade_20_minor.sql:530: ERROR:
LINE 1: DO language 'plpgsql' $$
I'm guessing PostgreSQL 9.1 is required, but in that case we should bail
out at configure time.
By the way, have you read the recent apologia requesting support for older
systems ? I'm always happy to support older versions of dependencies...
And I'm on Ubuntu 10.04, btw.
http://blog.cleverelephant.ca/2012/08/postgis-apologia.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1971>
