[postgis-devel] [PostGIS] #1869: ST_AsBinary is not unique (again)
PostGIS trac at osgeo.org
Mon Sep 3 04:34:24 PDT 2012
  Reporter:  nidi     |       Owner:  robe
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 2.0.2
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Comment(by erilem):
 So this ticket's description reports about
 SELECT ST_AsBinary('POINT(1 2)');
 failing with this error:
 ERROR:  function ST_AsBinary(unknown) is not unique
 I've myself reported on a UNION-based query that also fails with a
 similar, though different error:
 ERROR:  function ST_AsBinary(bytea) is not unique
 Here's a simpler query that triggers the same error:
 SELECT As_AsBinary(ST_AsBinary(ST_GeomFromText('POINT(1 2)')));
 {{{ST_AsBinary}}} returns a {{{bytea}}}, which is a type that
 {{{ST_AsBinary}}} does no longer accept as its input argument.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1869#comment:7>
