[postgis-devel] [PostGIS] #1977: Segfault on ST_Intersects
PostGIS trac at osgeo.org
Wed Sep 5 12:28:51 PDT 2012
 Reporter:  andrepl                 |       Owner:  pramsey
     Type:  defect                  |      Status:  new
 Priority:  critical                |   Milestone:  PostGIS 2.0.2
Component:  postgis                 |     Version:  2.0.x
 Keywords:  st_intersects segfault  |
Comment(by robe):
 andrepl,
 This isn't crashing for me on my PostGIS 2.0.1 nor PostGIS 2.1.0
 instances.
 I ran:
 select st_intersects(g,g2) from reduce;
 and returned true.
 Can you please provide the output of the following query:
 select version() || ' ' || postgis_full_version();
 It's also possible that the geometry is malformed in the database but
 fixes itself when it goes thru the output process.  I've had a case like
 that happen to me.
 To test, you can reload the dump you have here into a new database and see
 if it crashes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1977#comment:2>
