[postgis-devel] [PostGIS] #1980: Winnie hiccuping on mathml doc html
PostGIS trac at osgeo.org
Thu Sep 6 03:56:15 PDT 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Just noticed  Winnie is hiccuping when trying to deal with the mathml
 stuff.  As a result the DE-IM is not being formatted right.
 http://www.postgis.org/documentation/manual-
 svn/using_postgis_dbmanagement.html#DE-9IM
 Error is
 I/O error : Attempt to load network entity
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 postgis-out.xml:11: warning: failed to load external entity
 "http://www.w3.org/Math/DTD/mathml2/mathml2.dtd"
 %mathml;
 Entity: line 1:
  %mathml;
 I/O error : Attempt to load network entity http://www.oasis-
 open.org/docbook/xml/4.5/docbookx.dtd
 postgis-out.xml:104: warning: failed to load external entity "http://www
 .oasis-open.org/docbook/xml/4.5/docbookx.dtd"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1980>
