[postgis-devel] [PostGIS] #1987: Results given by ST_Simplify inconsistent between PostGIS 1.5.2 and 2.0.1
PostGIS trac at osgeo.org
Mon Sep 10 00:18:58 PDT 2012
 Reporter:  ChrisInCambo  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  high          |   Milestone:  PostGIS 2.0.2
Component:  postgis       |     Version:  2.0.x
 Keywords:                |
Comment(by ChrisInCambo):
 Thanks, Strk. Is there any kind of workaround, because for me (and I
 imagine most others) is to reduce the size of the data down the wire. At
 the moment, using ST_Simplify isn't shaving off enough to make it viable.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1987#comment:2>
