[postgis-devel] [PostGIS] #1991: geocode really slow on PostgreSQL 9.2
PostGIS trac at osgeo.org
Wed Sep 12 08:59:04 PDT 2012
 Reporter:  robe            |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.2
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Okay it seems in 9.2, reducing the join collapse limit makes it behave as
 fast as the old versions
 e.g.:
  SET join_collapse_limit = '2';
 Make both queries work at the faster speed and use the bitmapor strategy
 again.So not sure this is a real issue or just something to be cognizant
 of.
 The default is 8, but if I increase above 4 it gets bad.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1991#comment:1>
