[postgis-devel] [PostGIS] #1780: ST_GeoHash should support geography type without cast
trac at osgeo.org
Thu Sep 13 13:24:52 PDT 2012
Reporter: toofishes | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by robe):
and of course I think the below will no longer work
SELECT ST_GeoHash('POINT(0 0)');
Though I haven't confirmed. That'll teach'em -- they'll have to do
SELECT ST_GeoHash('POINT(0 0)'::geometry);
If my suspicion is correct, should we catalog this as a breaking change,
or add the
'Unknown' hack.
We have same issue with ST_Segmentize BTW.
Anyrate we should probably add the unknown hack to the legacy file if we
don't make it part of the core file.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1780#comment:4>
