[postgis-devel] [PostGIS] #1997: regression failures under windows 9.2 64-bit release
PostGIS trac at osgeo.org
Thu Sep 13 19:39:21 PDT 2012
 Reporter:  robe      |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 I have to verify if same issue on my regular 32-bit chain but on mingw64
 my 9.2 is showing this, but might be something amiss with my compilation
 or something since I recently built 9.2 release.
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  binary .. ok
  regress .. failed (diff expected obtained: /tmp/pgis_reg/test_24_diff)
  regress_index .. failed (diff expected obtained:
 /tmp/pgis_reg/test_25_diff)
  regress_index_nulls .. failed (diff expected obtained:
 /tmp/pgis_reg/test_26_diff)
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. failed (diff expected obtained: /tmp/pgis_reg/test_37_diff)
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  geography .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. failed (diff expected obtained:
 /tmp/pgis_reg/test_61_diff)
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. failed (diff expected obtained: /tmp/pgis_reg/test_68_diff)
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. failed (diff expected obtained:
 /tmp/pgis_reg/test_76_diff)
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  in_geojson .. ok
  uninstall .
 Winnie 9.1 x64 bit is passing tests fine.
 I've ruled out 9.2 as primary culprit since Debbie is passing with flying
 colors and she's running 9.2 release version too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1997>
