[postgis-devel] Hitting boxes (lack of) again
Sandro Santilli strk at keybit.net
Fri Sep 14 01:21:36 PDT 2012
Also, I'd want ST_Width and ST_Height functions for boxes,
or more general ST_Range(box, dimension) if we plan to support
multidimensional boxes.
Did we have a wiki page or ticket to take note of this ?
--strk;
On Tue, Sep 11, 2012 at 01:19:50PM +0200, Sandro Santilli wrote:
> It just happened again: I need a box...
> It is to compute the extent of a query _outside_
> of the database (since the db already performs a first scan
> so why performing a second one ?), so for each geometry in
> the result I want to get its bounding box, which I'll parse
> and expand as necessary.
> Now: what's the recommended way to do that ?
> ST_Envelope will give me a POLYGON, which is harder to parse
> than a nice BOX.
> ST_Extent is an aggregate, don't want that, want a _single_
> value.
> What should I do, then ? ::box2d ? ::box3d ? ::box3d_extent ?
> It would be very nice to have a single view on the concept.
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your data
>                                        ~~ http://strk.keybit.net
