[postgis-devel] [PostGIS] #1995: Build errors for 1.5 with PostgreSQL 9.2.0
PostGIS trac at osgeo.org
Fri Sep 14 14:19:48 PDT 2012
 Reporter:  darkpanda  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  high       |   Milestone:  PostGIS 1.5.6
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
Comment(by darkpanda):
 Ah, didn't notice that.
 We're in the middle of upgrading both PostgreSQL to 9.2 and PostGIS to
 2.0, so yeah, we're moving to PostGIS 2.0, but we just want to smooth out
 the transition by doing one and then the other. We also found that
 pg_upgrade wouldn't let us transfer from our older 9.0 and 9.1 clusters to
 9.2 without having all of the various shared modules available in each
 cluster, so we needed to have both PostGIS 1.5 installed for the
 conversion process and later 2.0 installed for the PostGIS upgrade.
 So no, we don't have a hard reason to not being using 2.0 as that's our
 plan anyways, but the upgrade path via pg_upgrade isn't an option without
 having both 1.5 available temporarily alongside 2.0 as far as I can tell.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1995#comment:2>
