[postgis-devel] [PostGIS] #1995: Build errors for 1.5 with PostgreSQL 9.2.0
PostGIS trac at osgeo.org
Fri Sep 14 23:22:05 PDT 2012
  Reporter:  darkpanda  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  high       |   Milestone:  PostGIS 1.5.6
 Component:  postgis    |     Version:  2.0.x
Resolution:  wontfix    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Okay.  I guess my general opinion on this is: It would be better to -
 1) Upgrade to 2.0 first before upgrading to 9.2
 or
 2) Just do a dump restore rather than using pg_upgrade for this case you
 have.
 The main reason being, you are going to have to dump restore your database
 anyway to go from 1.5 to 2.0 since there is no soft upgrade path going
 from 1.5 to 2.0.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1995#comment:3>
