[postgis-devel] [PostGIS] #1997: regression failures under windows 9.2 64-bit release
PostGIS trac at osgeo.org
Fri Sep 14 23:24:32 PDT 2012
  Reporter:  robe      |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.1.0
 Component:  postgis   |     Version:  trunk
Resolution:  invalid   |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 I think I may have been missing iconv or something path settings.  My 9.2
 32-bit is going thru okay after I copied.  Still need to check my 64-bit,
 but I'm guessing it is the same issue
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1997#comment:1>
