[postgis-devel] [PostGIS] #1995: Build errors for 1.5 with PostgreSQL 9.2.0
PostGIS trac at osgeo.org
Fri Sep 14 23:54:55 PDT 2012
  Reporter:  darkpanda  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  high       |   Milestone:  PostGIS 1.5.6
 Component:  postgis    |     Version:  2.0.x
Resolution:  wontfix    |    Keywords:
Comment(by darkpanda):
 Yeah, the only problem in that case is where you have multiple databases
 in the same cluster and they can't for whatever reason all be
 transitioned, but I'll worry about that on my end. Cheers.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1995#comment:4>
