[postgis-devel] [PostGIS] #2002: Circle geometry handling
PostGIS trac at osgeo.org
Mon Sep 17 04:08:18 PDT 2012
 Reporter:  xificurk  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
 The documentation states in 4.1.3. SQL-MM Part 3:
 "The exception to this is for a closed circle, where the start and end
 points are the same. In this case the second point MUST be the center of
 the arc, ie the opposite side of the circle."
 But it seems that postgis does not handle these geometries well.
 => SELECT
 ST_AsText(ST_CurveToLine(ST_GeomFromText('CURVEPOLYGON(CIRCULARSTRING(-1
 0,1 0,-1 0))')));
         st_astext
  POLYGON((1 0,-1 0,-1 0))
 The result is invalid polygon. The workaround is simple - use more points
 in circular string, e.g.:
 => SELECT
 0, 0 1, 1 0, 0 -1, -1 0))'), 2));
 st_astext
  POLYGON((-1 1.22460635382238e-16,-0.707106781186547
 0.707106781186548,6.12303176911189e-17 1,0.707106781186548
 0.707106781186547,1 0,0.707106781186548
 -0.707106781186547,6.12303176911189e-17 -1,-0.707106781186547
 -0.707106781186548,-1 0))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2002>
