[postgis-devel] [PostGIS] #2003: Revise buildbots to initialize different pg clusters on different ports
PostGIS trac at osgeo.org
Mon Sep 17 06:25:48 PDT 2012
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:
 Keywords:             |
 If changes are made to both PostGIS 2.0/2.1 at the same time, there is a
 high likeliness during regress that the two jobs collide with each other
 since they are trying to initialize the same clusters.
 The init and start/stop should be revised to take as input postgis version
 number so that we can create data clusters specifically for said version
 to prevent job collision.
 I think similar issue with the pgis_regress temp folder or whatever it's
 called.  This will become more important as we test more permutations of
 libraries.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2003>
