[postgis-devel] [PostGIS] #2010: Can't install trunk on 9.3 instance
PostGIS trac at osgeo.org
Thu Sep 20 06:47:56 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Hmm don't see why it would be different than 9.1,9.2 they all go thru the
 same path, so I would expect missing cleanup to affect them as well.
 Unless it was something wrong with my compile of 9.3, but then I'd expect
 the service to not start at all.
 I'll give it another go.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2010#comment:2>
