[postgis-devel] [PostGIS] #2003: Prevent different branch builds from colliding (was: Revise buildbots to initialize different pg clusters on different ports)
PostGIS trac at osgeo.org
Thu Sep 20 20:49:29 PDT 2012
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:
 Keywords:             |
Comment(by robe):
 strk I revised to have initialize clusters based on port ad have the
 different pranches use different ports, however there is still the issue
 of the pgis_reg folder
 how do I control that to have each branch use a different one.
 How do I override this again.  I think that is why prmasey's harmless
 commits to both 2.0 and 2.1 caused bizarre regression failures.  Sorry
 about that pramsey, if Debbie yelled at you :).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2003#comment:1>
