[postgis-devel] [PostGIS] #1997: regression failures under windows 9.2 64-bit release
PostGIS trac at osgeo.org
Fri Sep 21 23:20:09 PDT 2012
  Reporter:  robe                   |       Owner:  robe
      Type:  defect                 |      Status:  new
  Priority:  critical               |   Milestone:  PostGIS 2.0.2
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by robe):
 Okay seems to be some sort of memory leak or something.
 An example that crashes the service (only my 64-bit the 32-bit seems fine)
 If I run this statement 3-4 times on the 3rd to 4th time it crashes the
 service
 select '165', ST_AsEWKT('POLYGON((0 0 0, 1 0 0, 1 1 0, 0 1 0, 0 0.1 1))');
 I don't recall having this issue when testing Pg9.2rc1, so this may be a
 new development.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1997#comment:5>
