[postgis-devel] [PostGIS] #2010: Can't install trunk on 9.3 instance
PostGIS trac at osgeo.org
Sat Sep 22 01:30:20 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Okay when I compile under mingw64 it doesn't even get past compile and
 gives a more informative description:
 c:\ming64\projects\postgis\postgis-2.1.0SVN\postgis/geometry_estimate.c:318:
 und
 efined reference to `GETSTRUCT'
 c:\ming64\projects\postgis\postgis-2.1.0SVN\postgis/geometry_estimate.c:330:
 und
 I'll try to see if I can patch that
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2010#comment:7>
