[postgis-devel] [PostGIS] #2012: Regress failures on 9.3dev
PostGIS trac at osgeo.org
Sat Sep 22 01:49:04 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Running tests
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  geography .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. failed (diff expected obtained: /tmp/pgis_reg/test_
 f)
  dump .. ok
  dumppoints .. ok
  wmsservers .. failed (diff expected obtained: /tmp/pgis_reg/test_64_diff)
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  in_geojson .. ok
 )uninstall .. ok (4077
 This is under mingw64.
 I'll confirm with debbie after I've committed the 9.3 fix to get trunk to
 compile with 9.3
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2012>
