[postgis-devel] [PostGIS] #2010: Can't install trunk on 9.3 instance
PostGIS trac at osgeo.org
Sat Sep 22 02:01:10 PDT 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.1.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed at r10320.  I had to make conditional since spot checking 9.0, it
 wouldn't compile since access/htup_details.h doesn't exist.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2010#comment:8>
