[postgis-devel] [PostGIS] #2020: Regress windows 32 9.2 (was: Regress windows 32 9.2 and 9.1 x64)
PostGIS trac at osgeo.org
Fri Sep 28 13:18:57 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 I misspoke a bit the 9.1.4w64 instance is passing thru fine. It's the
 9.2.0w32 instance I have that is failing the above.  Seems to have been
 failing since:
 r10335
 Last good one looks like: r10333
 Why one fails and the other passes is a bit strange.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2020#comment:3>
