[postgis-devel] GSoC PostGIS Raster Ideas, Implement a set of geometry to raster functions
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Apr 17 07:52:31 PDT 2013
Hi Ivan,
Basically we need to be able to interpolate from very few points or from millions of them. Those points have to be stored as PostGIS GEOMETRY and we want to be able to produce only one raster (passing the georeference metadata similar to what we pass to ST_AsRaster) or a tiled raster coverage based on an already one.
Could you speak more about the approach you would use to interpolate millions of points into a tiled raster coverage based on another one, which would be, for me, the most difficult case?
Are you aware and do you understand Martin Isenberg approach for "Generating Raster DEM from Mass Points via TIN Streaming" (http://www.cs.unc.edu/~isenburg/)?
Bborie also has a strong opinion about (against) interpolation. Maybe we would like to hear about its point of view?
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org [mailto:postgis-devel-
> bounces at lists.osgeo.org] On Behalf Of Ivan Alargic
> Sent: Wednesday, April 17, 2013 10:12 AM
> To: postgis-devel at lists.osgeo.org
> Subject: [postgis-devel] GSoC PostGIS Raster Ideas, Implement a set of
> Hi all,
> Can someone tell me if the idea about implementation of geometry to
> raster functions is still available for GSoC 2013?
> I am particularly interested in the implementation of ST_Interpolate
> function but I would be also ready to implement other geometry to raster
> functions if it would be required.
> This topic is interesting to me because it is related to my research about
> storing and processing of LiDAR data in PostGIS. Moreover, I posses
> experience with Triangle library, which I used to generate terrain models
> from LiDAR data and interpolate elevation.
> Regards,
> Ivan Alargic
> University of Novi Sad, Serbia
